Oil leak after oil change
Discussion in 'Touring Models' started by katoomer, Sep 20, 2009.
  1. katoomer
    katoomer Member
    14
    Hi fellas,
    My bike was leaking oil from the right of rear cylinder after servicing. Checked oil level slightly above max, so ignored. After a while, leak stopped. Checked oil level normal.
    Question: Was the oil leak due to too much oil poured in during servicing, or something else?
    50
    Never over fill the engine, if anything a bit under the full line like between the add and full mark is desired and recheck the level when hot.
    Overfilling will cause it to come out the air filter breather lines.
  3. R. Lewis
    2,183
    5
    Yes - to much in her !
  4. katoomer
    katoomer Member
    14
    Wow that's fast! Thanks, a relief to know that. Say, any impact on engine if overfilled and not drained?
  5. glider
    50
    Yes, it could foam the oil and loose lubrication.It can also push out the vent tubes and make a mess. Best if not overfilled.
  6. katoomer
    katoomer Member
    14
    Gotcha!
