I would not go by that method. Since it is a dry sump system, you never drain all the old oil out during a change.. I just add fresh oil until the stick reads the proper level when HOT while on the Jiffy stand.
If you go by a "measured amount", most times you will come up with an "overfill". That will almost always sludge up your IAC stepper motor.
