Oil change
Discussion in 'Sportster Models' started by jel123, Apr 11, 2009.
  1. jel123
    jel123 Active Member
    157
    1990 sporster how do you drain the oil and how much does the primary hold
  2. fin_676
    5,788
    153
    287
    drain plug is on the bottom of primary cover towards rear of the bike
    if its a 4 speed i think its 38 fluid ounces make sure the bike is upright when you drain it or it wont all come out
    egine oil tank drain pipe is secured to a boss under the battery tray simple spring clip to remove it
    as per normal if the oil is warm comes out a lot quicker
