I modified a Ocean Spray cranberry juice bottle...cut the small side back a bit, but retain the nozzle end intact so you can "cap" it until your wish to drain contents in your pan...no muss no fuss...and actually a bit healthier for you
Thanks for that most useful info FerrousB! I have copied what you have written and added it to my Harley Folder on my computer for future reference. Seems like I just might get all three!Reading the whole post, it looks like some of you are talking about 2 different things...
chuck60 mentions: "Oil Catcher Drain Oil Funnel", part #63794-10
bavery on the other hand, appears to be talking about: "Low-Profile Oil Drain Pan", part #63795-10
Not wanting to be left out, I suggest you add one of these to your collection. "Primary Oil Fill Funnel", part #62700015 or #63797-10 If you're getting into the primary/derby cover don't forget, on some models it is a #27 Torx driver, NOT a 25! It's posted elsewhere on this forum and I have confirmed on my bike.
Cheers!
I've tried several variations of the above mentioned plastic solutions, but could not seem to get a good seal under the filter. What has worked better for me is to form a "Catcher" out of aluminum foil, then fashion a trough to the catch vessel.
I do this. It helps....another tip is to punch hole in oil filter (lowest part @ end) & let it drain before removal.
