Thanks classic, Haven't been out in the garage for a while (cold, honey do list) I definitely need to check the tracking. After running a straight edge down the 2 sprockets they are a 1/2" off. Cant believe someone would put it together like that. Bought a new front sprocket with a 1/4" more offset. Feeling between the tire & fender there is quite a bit more room on the brake side. But no spacers I could take out to move it over that way. So have you ever heard of machining the brake caliper bracket down to make room? I know alot of things come into play here. I first need to check tracking, then put on new front sprocket, see how much room I have between chain & tire,frame. If the tracking checks out ok & clearence is good, I could then take the other 1/4" out of the spacer behind the rear sprocket. But the different gaps between the fender & tire bother me. O and that monkey Gary I know where you can shove that pipe!
