Oetiker Clamps - Oetiker Clamp and Plier kit Here is a link of the OEM type fuel lime clamps and tool needed, You can buy the clamps separate and the tool can also be had separate from other manufactures
CV Joint Boot Clamp Pliers -- KD 424 This is the one I have in my tool box, it works on all of the Oetiker clamps I have run into since the early days of import cars with these clamps on fuel lines and CV axles
Hello,Although these clamps could certainly be used,They are not quite the same type as the factory spec clamps which have a single ear.They can be found quite inexpensively on E-bay of all places.It will take a bit of research to determine which size you require.Ed
