My odometer was working fine, then I stopped for fuel and reset the trip meter to zero. Then I pulled out and the odometer no longer worked. Any suggestions to what may have happened?
Being a 91, you have a cable drive speedo off the front wheel?
If you do and the speedo is working OK, then the speedo is at fault, if the speedo isn't working, you have a broken cable or speedo drive on the front wheel.
I doubt you have an electronic speedo but if you do read this....
