o ring chain
Discussion in 'Classic Models' started by blewcrab, Mar 7, 2011.
  1. blewcrab
    blewcrab Member
    8
    what is the advantage for using 0 ring chain ?
  2. ultra...good
    ultra...good Banned
    302
    You don't have to oil them
  3. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    The orings seal the gap between side plates and pins, keeping lube in, and dirt out.
  4. Jack Klarich
    They will out last a conventional chain they hold the lube in better and longer
  5. mrwizz
    mrwizz Member Contributor
    52
    I've run o-ring chains on my shovels for years. They hold lube longer. adjust less, and last longer.
  6. ultra...good
    ultra...good Banned
    302
    On my 74 XLCH, I always thought that I had a chain oiler, and that it was just adjusted to a point where it was sending too much out. To my surprise however, it turns out that it was just leaking oil from so many different places up front, that it appeared that I had a chain oiler. Long story short, after a bunch of new gaskets and seals, no more oil leaks, and a new o-ring chain.
    :newsmile091:
  7. NEWHD74FAN
    8,191
    98
    19
    The single advantage of a chain over belt is strength for given width. The use of O-ring chain is lower maintenance NOT maintenance ignore...! You still have to keep it clean and "lightly" lubed, but not use the "sticky" chain lubes that attract and retain dirt. MOCO really did a good thing by going to low maintenance belt drive. If you need more strength (for high horsepower applications) you can go to a wider belt and pully setup to continue the advantage.
  8. blewcrab
    blewcrab Member
    8
    Thanx,, Looks like I will order o ring chain for my 65FL :hii
  9. ultra...good
    ultra...good Banned
    302
    You cannot say 65 fl without showing us a picture or two. Thats just not right..............
  10. Webbtron
    Webbtron Banned
    583
    When I bought my o-ring I think it said lifetime on there some where, which brought out the cynical snort, but it is one of the best things I ever put on. I think back then it was $45 compared to a $17 or $18 standard chain. Over 20 years on there but 10 were in storage and I only adjust it when I need tires. Compare that to making an adjustment at least 3 times a summer.
