Not finding neutral when engine is running
Discussion in 'Softail Models' started by Relaisblower, Oct 3, 2011.
  1. Relaisblower
    Relaisblower Member
    Hi there ,
    Having problems whit a friends 99 springer shifting into neutral.
    I already changed the primary oil and adjusted the clutch and cable.
    Still the same problem .
    The primary oil is very smelly and dark collored .
    I will change the oil again and also change the transmission oil .
    What would be the problem here ?
    Thanks.
    Regards,
    Alain
    cheers
    50
    Possibly overfilled primary or you could use a better grade of trans lube like Spectro oil or Redline.
    Harley Davidson Community
  3. Relaisblower
    Relaisblower Member
    Thanks Glider.
    Can I use Mobilube 1 SCH 75w90 for the gears ?
    Regards,
    Alain
  4. Dr.Evil
    Dr.Evil Junior Member
    694
    5
    Try these HDT Polls, they tell you what the members are using
    Primary Lube Poll - Harley Davidson Community
    Trans Oil Poll - Harley Davidson Community
  5. Slo-Ryd
    Slo-Ryd Junior Member Contributor
    527
    23
    You mentioned adjusting the clutch and cable. Did you check the primary chain tension? I had the same problem last year and it turned out to be the primary chain was a little too tight. Reset to specs and I can find neutral everytime now. Just my thought:s
  6. glider
    50
    Not familiar with the "SCH" designation you posted but the Mobil 1 75/90 or 75/140 will do nicely. It's just that the Spectro is a bit better from my experiences. I have used the Mobil 1, Redline and switched to Spectro and never changed from Spectro.
  7. bobster12
    bobster12 Member
    6
    Thats what happened to me, fixed it and all good since
  8. Relaisblower
    Relaisblower Member
    Thanks for the good info .
  9. fin_676
    5,789
    153
    288
    If you are looking for spectro oil products in europe they should be available through a zodiac dealer
  10. Jack Klarich
    How old is the cable? Is it stretched?
