Not enough lights in the rear of my 2011 FLTRU
Discussion in 'Touring Models' started by FLIPPA, Mar 6, 2011.
  1. FLIPPA
    FLIPPA New Member
    Are the rear fenders on the 2011 Ultra Classic-FLHTCUI & Roadglide Ultra- FLTRU the same. I want to add the Bumper running light on the rear fender...On the Ultra Classic this is added rear lighting....If the answer is yes, are the wiring harness the same....
    vr,
    New kid on the block
  2. Trek
    Trek Junior Member
    575
    Hey Flippa, I don't have that answer but wanted to melcome you to the forum. So welcome. I'm sure someone will be along shortly with an answer.
  3. FLIPPA
    FLIPPA New Member
    Thanks
  4. dbmg
    dbmg Guest
  5. Grillfish
    Grillfish Junior Member
    652
    On my 09 Rg, it did not have the Street Glide tri-bar running/brake light. I can't recall if the RGU has that. If not, maybe that is an idea. I also, added a Bright A.. Light. It's so bright, it's amazing.
    Anjoy that nice ride of yours!
    Ride safe and have fun.
  6. HDDon
    5,544
    133
    229
    Grillfish can you give us info on where to buy the Bright A light? Thanks, Don
  7. jerrybombard
    jerrybombard Active Member
    115
    you should be able to make the switch to the tri bar light. And inside the tail light housing is the female plug for the light.
    I just added a tribar setup like harley's, but it also had a licese plate mount, so I was ablt to move the plate below the taillight. It came from Kuryakyn. Love it.
    Add the brake/turn/run module and your'e all lit up.
  8. Topcop
    Topcop Member
    17
    Hey friend, I got LED saddlebag and tourpac lights but..... nothing did it like my BrightAss tail light. Man, it is the cat-daddy. Costs about $200 but, catch it on sale for about 20% less. It does get your attention bigtime. I got mine set on 7 flashes and then solid on brake and medium intensity as a tail light. They have a website just use a search engine for Brightass lights. p.s. I got mine from my local H-D shop when they had a big sale. happy trails...
  9. trvlr
    trvlr Junior Member
    424
    Topcop, did you local HD shop have the BAL in stock when you bought it, or did they have to order it for you? The local HD shop here has never had one of these in stock that I've seen, else I'd jump all over a 20% sale on one of these.
  10. philmartin
    philmartin New Member
    I added the Airwing Luggage and Saddlebag Racks with lights.
