free website stats program NooB needs advice | Harley Davidson Forums
NooB needs advice
neonflx
I have an 09 Road King and just did some engine work as follow
S&S 106 cyl/piston kit
T-Man Stage 2 Pro Touring Head Work
T-Man 625 Cams
10.5:1 ratio
Throttle Body redone by HPI from 50mm to 54mm
Zippers A/C
V&H Power Chamber with Rinehart Slip-ons'
TTS Master Tune
Have the work done at a local HD dealer
My Dyno numbers are 110 hp and 118 torque
My questions is are those numbers about right for this setup or should they be a little higher, honestly I was expecting a bit more than that, but since I'm not that experience I would like to know what you guys think, any comments would be welcome and thank you.
I have not pick the bike up yet as I'm in Cabo right now, will pick up around the 30 of this month
Welcome to the HDT forum....
I would be happy with those numbers and CABO also!
Hard to Keep the front wheel on the ground with that POWER!
09 FLHR/ full stage one TFI fueler
Ummmm wait till you ride it before you judge?? I think you will be very happy with that power unless you wanna race it then....well bring buckets of money. HAHAHA
Thanks to all of you guys, that helped put my mind.
Now I'm really looking forward to break it in good and do some good riding, once again thanks a lot.
those #'s sound good to me.I'm doing the same kit to my2010 st. glide except i had it bored to 117".I talked to T.R.the owner of t-man he said i should get at least 120 h.p. & 120 tq out of mine so i would think they did a good job on tuning yours.If your not sure call T.R. and ask him he'll let you know what kind of#'s you should get. have fun and hold on tight jim1102
