nology wire and ion sensor
Discussion in 'Electrical' started by fabrozor, Nov 2, 2010.
  1. fabrozor
    fabrozor Active Member
    237
    Hi,
    I got a 2005 FLHTi (injected)
    Would the replacement of "stock spark wire" with "Nology wire", have bad effects with the "ION sensor" or other parts of the ignition system ?
    50
    The system was designed for the stock wires and changing to a different brand can sometimes effect the system because of the different resistance in the wires.
  3. fabrozor
    237
    Thank you Glider :D
  4. Jack Klarich
    Agree here , Nology seems to have capacitors built in to there wires if I remember right
  5. fabrozor
    237
    Capacitors would be disturbing ?
