No throttle response (TGS)
Discussion in 'Electrical' started by fortmac, May 14, 2012.
  1. fortmac
    fortmac New Member
    4
    Hi there, I just installed different bars on my new bike (2012 FLHTK). I replaced the TGS with the new one from Harley with extended wiring. As instructed in the service manual I turned the ignition on and off four times to set the idle. The bike fired up right away and I checked out all my switches and everything seemed OK. When I rolled on the throttle to pull away, nothing, still just stays at idle. I tried it several times and it will not increase RPM. I even plugged the original TGS in and tried it, no luck. Is there something that needs to be reset ? Any ideas ?
  2. HDDon
    5,562
    133
    236
  3. lordharold
    lordharold Active Member
    191
    could it have unplugged in the handle bars, it has happened to me when pulling hard through the bars..
  4. Hoople
    Hoople Account Removed
    7,198
    34
    Perform a WOW test to see if your posting any codes. There are DTC's for missing voltages & wires pertaining to the throttle.
  5. fortmac
    fortmac New Member
    4
    I purchased the TGS from HD with the extended wiring so I would have no plugs inside the bars to cause problems.
  6. fortmac
    fortmac New Member
    4
    I checked this A.M. on the way to work and I am showing a P1510 (throttle actuator control limited performance) and a P2138 (twistgrip position sensor correlation error).
    When I purchased the new TGS from HD the wiring colors were different than what was original. I don't think I made a mistake but will double check everything tonight.
  7. Hoople
    7,198
    34
    Yep, there has to be something about the wires that is incorrect. I read somewhere there was a color change in the kit. No damage will occur from miss-wiring. Manually clear the codes and see if they come back.
  8. fortmac
    fortmac New Member
    4
    Thanks, I had two wires installed in the wrong positions, reversed them and all is good.
