no start condition
Discussion in 'Engine, Fuel and Exhaust' started by jewelrider, Aug 14, 2008.
  1. jewelrider
    jewelrider Member
    12
    23
    hi my 08 roadking will not start when cold unless i crack the throttle help
    50
    You mention a Road King but your avatar area says street glide???
    Same engine anyway, could be the TPS or the temp sensor on the front head causing it. Let the dealer diagnose it after checking the values on both. That's what the warranty is for.
  3. jewelrider
    jewelrider Member
    12
    23
    thank-you glider
    TPS throttle position switch checked out ok , i will look at the front head temp sensor
  4. glider
    50
    The reason I mentioned the TPS is because opening the throttle on a start will change the parameters that are needed for a proper start.
