jerryw618
hello there i changed the brake pads yesterday , same way as i have before and now i dont have any rear brakes , pedal goes down too the pedal stop with no back pressure felt and brakes dont activate . its an 07 sporty 883L with almost 14k miles on it , could i have blown the master cylinder ? no leaks anywhere , brakes were bled and fresh dot4 fluid put in at 10k checkup and the brakes worked fine since then. I cant figure out what could have happened ?
now this morning i took the pads out pumped the brakes and the piston moved out . ok , i reinstalled the pads pumped the brakes and the piston moved out seated pads on rotor , but still no pedal pressure and no rear brakes , i think i might need too bleed the system again ???
