C Cricket New Member Sep 21, 2014 #1 I have a 2009 Street Glide and when I turn the ignition on... nothing happens. No lights, no sound from ignition nothing. Feels like the ignition is out? Any ideas?
HDDon Experienced Member Contributor Retired Moderators Sep 21, 2014 #2 First check the battery to make sure it is fully charged. Next check the battery connections at both ends. Make sure they are clean and tight.
D dbmg Guest Sep 21, 2014 #3 After checking cables and find ok, if no change check the maxi fuse it may have come loose.
0 03HD883R Active Member Sep 23, 2014 #4 I would also go around and check the fuse block out with a multimeter with it turned on.
