Do you have the 'Brake light Modulator' on it. The one that makes your turn signals brake/turn lights?
ok so far i have read all the wires from under the seat back and found no brakes. does anyone know which wire from the handle bars is the brake wire?
i checked for power under the seat, no joy. i checked for power at handle bars where they go under the tank, no joy. i have one wire off the right hand side that stays hot whenever the ignition switch is on. not sure what that is but none of the other wires had juice with or without the brake lever pressed.
