theklanchXL1200N
Hey guys having a problem with my 07 nightster. It won't start!! Seems like there is no spark, pulled the plugs and no spark (well it was still in the sun, so I'm pretty sure there is no spark) I am hoping it isn't the V&H fuel pak going bad..... hopefully just a coil? How much is a coil? I don't have too much done to the bike, fuel pak, pipes Screamin eagle air cleaner SE plugs SE wires, had almost zero problems till now. Last night when I parked it, as I was backing her into her spot in the garage, she stalled, and started right up, like 4 or 5 times. I figured it was because it was low on fuel and the little hill leading into my garage. So I went over to the gas station, like a block from my house, I turned out of my driveway going left and as I was letting the clutch out, it almost stalled. I rolled the throttle and kept it alive..... So I went and got gas, and came home, when I rolled the throttle and shifted into 1st gear to pull into the driveway, no motor action when I rolled the throttle.... in fact it stalled and I coasted in. I started it up and went around the block a few times in second gear, running the bike pretty good, getting the RPMs up a bit, and when I came back to the house and put it on the kickstand, it stalled and hasn't started!!! Now, like I said, I pulled the plugs and i'm thinking there is no spark, I really can't see one. Where should I start on this sporty? Coil? Ign module? Fuel Pak? Like I said, seems like there is no spark. It did throw a code....P0732, motor running rich? I don't know where to begin really, it isn't an old chevy. Any help would be super appreciated... I'm supposed to be hopping on to go to a wedding rehersal dinner...... looks like I'm walking, seriously.......
