Ok, I got my new PC-V in today along with my SE kit for my 09 Heritage. I started on the air cleaner and the old one came off fine. I mounted the new back plate and air filter no problem. The kit from HD has you use your cover and center screw. No matter how I try the screw is not long enought as the cover is 1/4 from touching new filter. I guess I can go to HD and ask for a longer screw but its the 1/4 inch gap. If I do and then try to tighten it down to the 6.5 Nm I am sure it will bend the cover. I am adding the PC-V in the morning. Has anyone had the same problem?
