New Bike Question
Discussion in 'Touring Models' started by BuffaloBill, Jan 1, 2009.
  1. BuffaloBill
    BuffaloBill Active Member
    177
    Good Morning Gang
    Yesterday going home from work I had to get out of the way of a motorist and accelerated very quickly from 1st 2nd and 3rd gear The engine felt as if it had a governor on it Is there a mechanism on the bike to protect it from over exceeding the RPM range?
    Ride Safe
    BuffaloBILL
    50
    The rev limit on most harleys with a stock download is 5800 RPM's. If you have a stage 1 upgrade it will be 6200 RPM's.
  3. Mr. Clean
    Mr. Clean Member
    14
    Yes, there is a rev limiter on these bikes. They are set at 5500 RPM at the factory. If you ever have a Stage 1 download done, the rev limit is raised to 6200 RPM. Also, some of the aftermarket fuel controllers will allow you to raise the RPM limit.
  4. tsp45acp
    tsp45acp Active Member
    296
    Yup, it does if it's fuel injected. Tracy
  5. Dr. Dolittle
    6,404
    118
    29
    Wow, you REALLY had to get away if you hit the rev limiter in the first three gears! Glad it turned out OK. Care to educate us with some details?
  6. tsp45acp
    296
    Only occassionally do I hit the rev-limiter in first or second. Haven't hit it in third yet--Been to 85 in third and either ran out of rd (country rds), or traffic (highways). First is between 42-45 mph, forget where second kicks in. Tracy
  7. BuffaloBill
    177
    Was at a stop light making a right turn into traffic halfway into the turn a car in the left lane changed lanes into my lane and had to hit the throttle I have to admit I could have waited a few more seconds to let "ALL" the traffic clear before turning on to traffic
    BuffaloBILL
  8. Dr. Dolittle
    6,404
    118
    29
    Sounds like great situational awareness and quick thinking to me.....nicely done!
