New battery
Discussion in 'General Harley Davidson Topic' started by Jeff Klarich, Mar 8, 2013.
  1. Jeff Klarich
    4,806
    103
    487
    Tried to start the bike today but only turned over slow, pulled the battery and to my surprise it's the org one dated January of 04. I think I got my moneys worth.:D
  2. fin_676
    5,779
    153
    285
    I had a similar issue about a year ago once i got the bike started i checked the voltage across the battery terminals when running and got 17.7 volts a new regulator dropped the voltage to 14.5
    So perhaps worth a wee check of what the charge level is like once you are near the battery anyway
  3. Jack Klarich
    Now that is good life from a battery:D
  4. 90FXRS
    90FXRS Junior Member Contributor
    461
    10
    9 years............Yes you definitely got your money's worth.
  5. NEWHD74FAN
    8,191
    98
    19
    Yep, I changed my 2004 Sportster battery about 2 years ago, then had to change the Batteries Plus one about 6 months or so ago, but they honored the 1 year warranty without pro-rating because of the intermittant battery terminal factory defect I had after only 1 month new. So those HD OEM batteries from 2004-2005 Made in PA USA were pretty darn good...! :)
  6. HDDon
    5,544
    133
    229
    Talk about squeezing a nickel till it cries!
  7. Jeff Klarich
    4,806
    103
    487
    No kidding, I bought the bike used and seeing it has high compression I thought for sure it would have gone through a battery or 2 but it's the org Harley battery dated Jan of 04.
  8. NYHarley
    NYHarley Active Member
    120
    I changed my battery last year, and also upgraded to a set of 2ga battery cables. Bike starts way better with the new cables.
  9. Jack Klarich
    :D Should start a bit better now too, wanna trade bikes for a few miles again:D
  10. HDDon
    5,544
    133
    229
    So there is the answer. You let Jack ride your bike and the battery dies! He does the same thing to camera batteries!:bigsmiley30:
