After stopped at a road construction for 5 min. turned on ign switch then stop/run switch (engine light went out and neutral light was on) hit start button and nothing. Put stop/run to stop and turned ign switch off. Turned them back on and started right up. Same thing happened later in the day getting gas but this was after a couple of starts with no problems. Is this the beginning of a neutral switch failure? Nuetral is only on when in nuetral. (o7 ultra-stage 1-true duels) No codes.
