Need some advice
Discussion in 'Softail Models' started by hntwrobin, Oct 2, 2008.
  1. hntwrobin
    hntwrobin Active Member
    236
    Ghost brackets are the way to go for saddlebags, you can use whatever bag you want and they go on and off real easy. Mini apes are not bad on a Fatboy, pullback risers may work for you don't know that you will get to 3" back though.
  2. mikefxst
    mikefxst Banned
    56
    check with Glider or any of the other forum Techs for fitment but on a stock softail standard (FXST) they came with similar stock harley handle bars but had 2 inch pull back risers which should give you the comfort your looking for
  3. glider
    Two inches up is about the limit without replacing cables, the 3 back would put you in the problem area.
    Here's some choices for bar choices.
    Handle Bar Specs Height/pull back/width (virtual pics) - Harley Davidson Community
