free website stats program Need some advice...... | Harley Davidson Forums
NickS
ok so my check engine light is coming on and off at different times. As per Glider I checked the code and the answer is rear O2 sensor failure. The thunderheader exhaust has o2 sensors but neither are hooked up. I assumed with the PCIII that they were eliminated. So i ordered a replacement 02 sensor eliminator plug. I can not for the life of me figure out where to plug it into it. Any help?
Reach down in the hollow beside your oil dipstick and grab the small harness down there,just pull it up and you will see the connector.
thanks steve. I found the eliminator. But there is only 1. Is this the Rear Sensor? Is the front located somewhere else?
Got it. No more code. Thanks guys I appreciate the help. Got one more....Any way of telling if a bike as a SE II or III kit from looking at it from the outside?
