I'm about to buy a 2004 Fatboy, all stock, and I would appreciate any feedback or info someone could provide for me about it. It's a big decision and I want to make the right one. Thanks.
Good luck with your bike!
Have it checked out carefully by someone that has experience with the earlier model TCs. There are two issues on the pre-2007 TCs that should be considered. First is the cam chain tensioning system used. These use spring loaded tensioners with a plastic shoes against the chains. There have been enough problems with this system that it merits attention.
Second, is the inner cam shafts support bearings. HD uses a cheap INA bearing that should be changed out to the Torrington alternatives as soon as there is a reason to get into the cam chest.
Here is some info on alternatives to upgrade the tensioners:
I've got to add that this bike would not be just a toy. It is my PRIMARY means of transportation and I'm going to be putting miles on it as if it were a car. I need to know I can depend on it. Any thoughts?
if it has a slight ringing sound when you start it, walk away!
