Need help with speedometer.
Discussion in 'Electrical' started by Milan, Sep 30, 2008.
  1. Milan
    Milan Account Removed
    I have a Diamond Digital Speedometer thats on the fritz. At idle the tach jumps around from 0 to 6000 RPM. Once the bike starts moving all the lights on it go beserk and flash on and off for a few seconds and then goes dead. The guy I bought this from is no help. One of those people that once he has your money then he has no more use for you. Anyone know of a repair shop that might be able to fix this for me?
    50
    What is being used to trigger the unit? If it's the speed sensor on the trans, that could be the problem.
  3. Milan
    The speedo part runs of a front wheel adapter which I have already changed. Still the same problem. I also replace the wiring harness with no luck.
  4. glider
    50
  5. Milan
    Unfortunatelly the guy I bought it from wont help. The manufacturer of the circuit board is Samsung #CCD-03MS14T, but I havent had any luck trying to contact them about it.
    Milan
  6. Milan
    Accessories Unlimited no longer carry this speedo so they cant help.
    Milan
  7. glider
    50
  8. Milan
    Thanks for trying to help. But they also no longer have access to this speedo. Apparantly Rivera Primo Inc. now has the only supply of these and since I didnt purchase this from them they cant/wont help. I e-mailed DSR a couple days ago and they dont work on these.
    Milan
