9 92FXRS Active Member Apr 13, 2009 #1 I have a '92 FXRS Low Rider Sport. It has Air Assist on the front forks. The fork seals are leaking & must be replaced. Is this a hard job ? Do you need special tools ? I can find so info for regular forks, but nothing for air assist
G glider Veteran Member Apr 13, 2009 #2 The only difference between air and non air is the manifold system on the top of the legs, otherwise the seal replacement is the same on both. This will give you an idea... Chrome Fork Slider Swap - Harley Davidson Community
