Need help!!!!! Plz
Discussion in 'Sportster Models' started by DG1200, Jan 20, 2016.
  1. DG1200
    DG1200 New Member
    3
    I have a 2013 1200 sporty 48 and i need some help bc some idiot free revved my sporty at a high rpm for about 5 seconds, long story short his face met my fist but i baby my sporty and it didnt hit the rev limiter but i just want to know since my sporty being revved high is a rare occurrence could it be hurt? Thanks
  2. dolt
    dolt Senior Member
    2,172
    103
    333
    Unless something was wrong with the motor before; no damage done. When motors are being dyno tuned, they see WOT for longer than 5 seconds multiple times.
    RibEye likes this.
  3. Jeff Klarich
    4,805
    103
    486
    First of all have you noticed any ill effects since this happened? If not and as you have said you baby it and this was a one time occurrence I'd be inclined to say no damage done.
    Harley engines are pretty bulletproof and can withstand high rpm's ( within reason of course) and I'd think if you were going to have an issue you'd know it by now. JMHO.
  4. DG1200
    DG1200 New Member
    3
    Thanks for helping me out bud, its my first harley and it's my baby. Thanks for helping me out
    Jeff Klarich likes this.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Probably no problems as it does have a rev-limiter... BUT doing a quick FREE high rev COLD is not in my Vocabulary...
  6. Jack Klarich
    On a cold engine NOT a good idea, If you are concerned run a compression test, change the oil and listen for noises
  7. nakkers
    nakkers Junior Member
    412
    13
    It's actually better for your baby to work it through the RPM range and all its gears. At least when properly brought up to temp.
  8. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    As a new HD owner, always good to be concerned. Bike should be fine & hope your idiot throttle jockey's face is Ok. Best to keep peeps off the bike...think of what could've happened if they slammed it into gear too...
