Need help picking right rear tire for 2011 FLSTN....
Discussion in 'Softail Models' started by DannyDeluxe, Jun 8, 2016.
  1. DannyDeluxe
    DannyDeluxe Member
    8
    My stock rear tire is Dunlop MU85B 16 77H.....I have an Avon Av71 on the front and I want my rear to match. So I want to use Avon Av72 on the rear. They come in 140/90 16B 77H
    or 150/80 16B 77V or MT90B16 74H...Can some tell me what my best option is out of these 3 choices. Greatly appreciated.. My front tire is Avon Av71 120/70 21www...... If that helps.
  2. tourbox
    tourbox Senior Member Contributor
    2,014
    209
    The Dunlop MU85 is a 140 tire. So I would say go with the 140/90/16 Avon Rear. The are the same size.
    tourbox
  3. dbmg
    dbmg Guest
  4. DannyDeluxe
    DannyDeluxe Member
    8
    That's the way I was leaning
  5. TQuentin1
    4,747
    144
    You can probably fit the 150/80 16B 77V Avon in there. Measure how much clearance you have around the sides of the current tire to decide. The MU85 and the 150/80 are almost the same nominal height (3 mm difference) so I don't see that as a factor. Just the width of the 150 and ensuring you will have the clearance.
    Cheers,
