free website stats program Need Advice | Harley Davidson Forums
Need Advice
Wamego
I am working on a 1993 Harley Dyna Low Ride with the 1340 Evo. The bike sat in a yard for around 5 years. It was seized, due to lack of use. I freed it and rebuilt the carbs. I got it running, only to find to the cylinder base gaskets were leaking like no other. Compression on back cylinder is around 92, front cylinder is 122.
I found oil seeping from a few inches above the base gasket, on rear cylinder. Is it worth honing the rear cylinder or should it be replaced due to small leak from above the base gasket.
