Must the rear tire be removed for fender replacement
Discussion in 'Softail Models' started by jc119misty, Mar 7, 2013.
  1. jc119misty
    jc119misty New Member
    Must the rear tire be removed to replace stock rear fender.
    with another stock rear fender.
    2003 heritage softail classic
  2. HDDon
    5,544
    133
    229
    It may not "have" to be removed, but my guess is that it will be much easier if it is removed.
  3. 90FXRS
    90FXRS Junior Member Contributor
    461
    10
    You don't have to remove the tire to get the fender off. Since the bolts are on the outside. There are plates on the inside of the fender that have the nuts welded to them. Depending on how big your hands are, putting things back together can be tricky. I've held a nut plate up inside, started one bolt, used a couple of screwdrivers to align and hold the plate to start another bolt.
  4. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    Not necessary, but IMO worth the effort. Tail light wires etc. are in channels, connectors to unplug/pull through fender grommets, nuts hard to reach. I do a neater job and the time spent R&R wheel is worth the aggravation to ME.
  5. jc119misty
    Thanks for the knowledge, just making sure there's no bolt in center/top of fender front side, battery side. I had replaced the front weeks ago.
    did not remove the front tire, but.... the back may be a different story.
    Thanks again for the info
  6. R. Lewis
    2,183
    5
    besides , if you take the tire off you can inspect, clean, etc.. the wheel and other spots on the bike easier also.
