move fairing mirrors up
Discussion in 'Touring Models' started by fabrozor, Mar 7, 2010.
  1. fabrozor
    fabrozor Active Member
    237
    Hi,
    I drilled holes in my fairing with the blue plastic guide provided with the fairing mirrors.
    Once mirrors installed and configured, it appears the holes are verticaly too low.
    I think to drill new holes above the old holes.
    How do you recommand to fill the old holes so that doesn't look too ugly ?
  2. ultrat
    ultrat Senior Member Contributor
    1,315
    Hello Fab id say at hardware store or eiectric store small plastic plugs varring sizes black color snap in. but mabe u have right on left & vise a versa. useing the template u should be ok .good luck...
  3. Mattman4403
    Mattman4403 Junior Member
    602
    Check at an auto parts store for trim plugs. Little plastic plugs with two to four ridges of saw teeth on them various sizes. Mostly used to hold trim pieces over metal. Like door sills and rear time in a SUV or hatch back car
  4. Troy1225
    Troy1225 Active Member
    166
    Could you contour some type of backing plate to cover the entire area then redrill? Just a thought.
  5. fabrozor
    237
    @Mattman : thanks
    @Troy : i don't anderstand what a backing plate is, and if it will mask the hole
  6. Troy1225
    166
    Fab....since I ride a Road King, I'm not real familiar with your fairing setup. By backing plate I meant some material contoured to fit over the area you drilled, large enough to cover the old hole and area where the new hole is to be drilled....a plate/washer to go between the mirror and fairing.
    Sorry if this idea is totally off base. Just trying to come up with a different idea to fix the problem.
  7. Butch
    Butch Active Member
    227
    Saw these at ACE Hardware as well. Back in the nuts and bolts section in one of those drawers on top of the bins.
    Oops, my bad fabrozor didn't see you were in France. For those in the USA this applies
  8. fabrozor
    237
    @ultrat : thank you.
    @Butch : we also have in europe similar shops as ACE hardware. I could try to find something in a drawer on the top of a bin like you said. Thanks.
  9. bikerfishman
    bikerfishman Active Member
    139
    The plug is not a bad idea and some guy on ebay sells them for 9.95 US
    but you could try this too,
    Get some JB weld and duct tape and tape the back side of the hole, mix the 2 parts of the JB weld and add a little black dye with it to get the right color,
    apply with a plastic speader like the ones used in body work,
    be sure to clean off excess residue before it drys.
  10. fabrozor
    237
    it sounds good
