Mouse cams
Discussion in 'Engine, Fuel and Exhaust' started by spdrcr, Jul 14, 2015.
  1. spdrcr
    spdrcr Member
    13
    I have been looking into making a cam upgrade. A bolt-in with a max of .510 lift, aka "mouse cam". I have a 2007 Wideglide 96 cui, with SE A/C and V&H slip-on's...pretty standard for a Stage 1. As for a tuner, I like the Dobeck EJK Gen 3. I know this set up will give me 100 HP and TQ. That is not what I am expecting or looking for.
    I have 3 cams in mind:
    Andrews 37
    SE 204
    S&S 510
  2. dolt
    dolt Senior Member
    2,186
    103
    342
    All the cams you listed need more than stock compression to shine. The Andrews 48 is a great fit for a cam only upgrade to a Stage I 96" motor.:s
    With a good tune, that cam in your configuration should hit about low 90s TQ and low 80s HP. You might not be able to tune to those numbers with the Dobeck tuner though; might take a Powervision or TTS and dyno time.:D
    PS
    I have seen that cam with same configuration as yours hit 100TQ/90HP but the tuning was done with TTS and the pull was in 6th gear.
  3. spdrcr
    spdrcr Member
    13
    OOPS!
    That should have read I know this set up will "NOT" get me 100 TQ an HP.
    Thanks dolt. the 90's and 80's would be a nice increase for the money that it would cost.
  4. coopernicus
    coopernicus Junior Member Contributor
    973
    98
    Hey spdrcr, I have the se 204 "mouse cams' in my 13 heritage and absolutely love them. The bike is a lot more fun to ride and I am only running the gen 3. Don't care about peak hp numbers or tq. Never been dynode and really like the way it rides.
  5. spdrcr
    spdrcr Member
    13
    Thanks coopernicus! As far as dyno numbers I don't care either. It's the seat of the pants that I want to feel. LOL.
  6. dolt
    dolt Senior Member
    2,186
    103
    342
    "seat of the pants" = "butt dyno" and both will register more with the Andrews 48. The '07 up heads flow better than the early heads, beehive springs will accommodate higher lift, so take advantage of what the Andrews 48 offers over the more "mousy" cams. By far the best cam only upgrade for a Stage 1 96" motor; trust me, you will love that cam.
    [​IMG]
  7. spdrcr
    spdrcr Member
    13
    Hey dolt you are not making this any easier! LOL
  8. stray dog
    stray dog Junior Member
    443
    Disagree! I think Dolt is making this very easy for you :rofl
  9. spdrcr
    spdrcr Member
    13
    After much debate and riding I am going to go with the Andrews 26H. I want a simple bolt in without any other engine mods to get a good improvement in TQ and HP and the RPM range fits my riding style.
  10. kdaddy
    kdaddy Active Member
    185
    38
    9
    I think you will be very very happy with the 26h cams. I have the 21s. KN air filter. Bumped the carb jet one size and run VH true duals. Its perfect for performance and reliability.
