More Torque
Discussion in 'Engine, Fuel and Exhaust' started by jim loson, Nov 3, 2012.
  1. jim loson
    jim loson New Member
    can you help - 2009 flhtcu with stage 1 ,pipes ,air breather ,a complete dyno and power commmander 5 , bike is at 79.36 hp and 92.09 torq - need more torq ! need suggestions - contimplating cams and clear head pipes
  2. HDDon
    5,543
    133
    229
    For the set up you have that is a great torque #. Are you pulling a trailer or sidecar? I know some are looking for more power, but I would be glad to have that much torque. Cams can give you more HP and torque but it might not be in the RPM range you like to run. I switched to gear drive on my 05RG and I gained more torque over friends running the same cams and chain drive.
  3. dolt
    dolt Senior Member
    2,172
    103
    333
    That's about right for a well tuned Stage I 96"er. You referred to "pipes"; OEM head pipe and mufflers? Not sure what you mean by "clear head pipes" but the OEM head pipe wroks well. You need a good set of slipon mufflers or just have your OEM mufflers re-cored with Fullsac baffles.
    More compression will make more torque. A set of Andrews 48 cams, set of good slipons and a retune will make a big difference.
  4. Cyclops
    Cyclops Active Member
    371
    The stock head pipes on the 2009 should already be 'clear', unless you have one of the California 2009s that had Cats.
  5. Checkers
    Checkers Member
    29
    I would call Fuel Moto and run it by them, they have seen it all and can point you in the right direction. See Fuel Moto USA.
