Jezza
Hi
Can anyone suggest a supplier who can sell me a Molex Connector Terminal Removal Tool. Part# HD-48114
I live in Tokyo, Japan and just called my local HD dealer, and was told it would take 2 months for them to order one for me!
Alternatively, has anyone got any good tips on how to get the pins out of the Molex terminal block? My bike is a 2007 Road King Classic. I have the HD service manual and the parts book. I have tried following the instructions in the service manual, and the wires still won't budge. I don't have the terminal removal tool, so I've tried using a paper clip pushed down into the hole beside the pin inside the terminal block to release the pin from the block, but that isn't working.
What I've done so far is:
Disconnect the pin and socket halves of the Molex connector.
Pry the sealing cap away from the bottom of the connector (where the wires enter the connector)
Using needle nose pliers pull the inside of the connector up about 4mm in the connector housing (this is the secondary lock, right?)
Push a paper clip down into the hole beside the terminal pin that I'm trying to remove and...nothing! It won't budge!
I've got a set of Namz wire extensions I'm trying to fit, so I can install a set of pull back bars, but unless I can get the pins out of the Molex connectors I might as well just cut and solder the wires the old way. It'll be quicker!
Any suggestions welcome please!
