Missing bolt - 2010 FLSTC
Discussion in 'Softail Models' started by Keithhu, Nov 12, 2009.
  1. Keithhu
    Keithhu Active Member
    133
    Any thoughts on this one? I noticed it as I was covering the bike up.
    Stuff Bucket - keithhu's Photos
    I cant imagine it worked itself loose, I certainly didn't take it off. I dont think this comes off as part of the 1K service (meaning the dealer fogot to put it on)- ??
    You'll find that open hole on a lot of bikes. Have no idea what it's used for, there was another post a while back on the same thing.
  3. Keithhu
    133
    Ok, thanks. Odd....
  4. glider
    I'd be curious myself what it's used for, maybe a call to the MOCO to find out would be in order?
  5. awall
    awall Member
    96
    I just went out and looked at my 09 and it's the same as yours
  6. stoertebecker
    stoertebecker Member
    21
    maybe it is a hole to screw in an eye to transport/secure the bike while transporting. Just a guess.
  7. HDDon
    5,543
    133
    229
    I can't speak for the MOCO but as a toolmaker sometimes holes are put in as a way to locate a machining process or to provide a hold for a machining process.
  8. CatWoman
    CatWoman Active Member
    181
    I have a similar hole on the right side of my bike.
    I'm with HDDon on this one - I have always suspected it was due to the machinery when initially it was put together at the factory.
    CatWoman :rider
  9. Keithhu
    133
    Could be, but if thats the case, would it be threaded?
  10. HDDon
    5,543
    133
    229
    Some datum points used for location are threaded some are reamed I can only surmise what this hole is used for. Unless the MOCO will release their maschining steps we will probably never know. The question I have is why don't they put a plug in the hole--- plastic, chrome?
