**Miss Piggy won't run**
Discussion in 'Touring Models' started by skizman, May 15, 2016.
Tags:
  1. skizman
    skizman Active Member
    147
    13
    Hey! After I repaired Miss Piggy after the wreck, (02 Road King).....(after you guys helped me with parts) I put about 50 miles on her. She started to run like it ran out of gas but it wasn't. I just made it up my driveway into my shop. Today it won't even start.
    Couple months ago I used compressed air to try to pop some dents out of the tank. Maybe I blew something or loosened something in the fuel system??
    I pulled the fuel pump out of the tank and I can't visually see anything wrong. That mesh filter is clean. Not sure where to go from here.
    Sure would appreciate any ideas from you gents!
    Thank you!
  2. STEVE07
    4,128
    68
    86
    Check the high pressure fuel line for pin holes
  3. joel
    joel Senior Member
    1,070
    143
    Glad to hear your doing well enough to ride.
    If the pump is out of the fuel tank did you replace the filter and flex hose?
    When you cycle the ignition switch do you hear the fueI pump and with a flash light do you see fuel movement or spray inside the tank? If you can, do a fuel pressure test.
  4. tourbox
    tourbox Senior Member
    1,902
    173
    You could use a couple jumper wires while the pump is out to see if it runs. You may also use the original wiring for that. Just make sure you have 12VDC at the external connector.
    tourbox
  5. skizman
    147
    13
    OK thanks. When I turn the ignition on, the fuel pump sounds sick compared to how it sounded when it was running good. Tomorrow I'll stick the pump partly in the tank and turn the ignition on to see it sprays gas inside or whatever. I think Advance auto parts will loan out a fuel pressure check gauge. That's the next step.
    Thank ya!!!!
  6. dbmg
    dbmg Guest
    I second what Steve07 has said about plastic lines in tank. They are notorious for pin holes causing loss of fuel pressure...
  7. Jeff Klarich
    4,845
    103
    496
    If you still have the pump assembly out you may want to replace the hose now.
    Even if it's ok now it's just a matter of time before it develops the pin holes.
    As stated above a pressure test would be on my list of things to check.
    Have you check for any codes?
  8. skizman
    147
    13
    Yeah.....I have to order a new rubber gasket for the top, so I think it would be wise to order those two fuel lines too.
  9. skizman
    147
    13
    Now that's what I was wondering about. How do you check for codes? I need to find a code checker gadget?
  10. dbmg
    dbmg Guest
