miles on tires
Discussion in 'General Harley Davidson Topic' started by harleybiker, Sep 23, 2011.
  1. harleybiker
    harleybiker Member
    22
    About (approx) how many miles do you put on you tires. I have over 8,000 miles and the tread still looks pretty good. Thanks
    hb
  2. SkootchNC
    SkootchNC Active Member
    111
    there are few "hard and fast" fact about tire life on a bike. Throttle position, engine braking,road conditions,and ambient temps all play a part, as does tire construction.
    I ride often in the NC heat... over rough as a cobb roadways. I tend to "gear and steer" through curves, and often engine brake.... with me Dunlop Elite-3's I average 12-13k, on the OEM D-402's, amd the Metzler M880, I averaged 8500.
    The "new" dual compound D-407, and American Elites, (for 2009 and later bikes) are supposed to last far longer. However there was a bit of a problem with the first batch of D-407... which seems to have been corrected
  3. Dr. Dolittle
    6,404
    118
    29
    Remember, it's not JUST the miles on the tire that determine when it should be replaced. Keep an eye out for tiny cracks, sometimes in the tread groove and hard to see, as the tire ages. You might want to consider a replacement if you see too many of these, regardless of mileage.
  4. bonsi57
    bonsi57 Active Member
    178
    Front 25,000
    Rear 15,000
    2010 EG Limited
  5. 01dynaglide
    01dynaglide Junior Member
    920
    i get about 30-35K on my front and about 15-18K on my rear.
  6. sharpscuba
    sharpscuba Banned
    945
    On my 07Electra-Classic up here in Wisconsin I am at 35k for the front and 12k or so for the back.
  7. HDSickness
    HDSickness Banned
    418
    99 road king with dunlop 402s I have 10,000 on rear and still could go maybe 2,000 more, very happy with these tires.,
  8. rking
    rking Active Member
    118
    I have 14,700 on my 2010 FLHX
  9. oldhippie
    oldhippie Senior Member
    1,122
    68
    43
    I have just under 17000 on my OE rear tire and it's due to be changed. Front was replaced under warranty around 7k for cupping. Too bad the replacement is also cupping.
    If I could find a road where I could only drive in circles, I could do another 6k on the rear:D.
  10. whacko
    whacko Junior Member
    462
    4
    On my original Michelin Scorchers I got 11k. They were not quite down to the wear bars (bars are set at 2/32) but I play it safe because I commute on mine and have to be prepared for riding in heavy rain. If I used my bike more for pleasure riding on weekends only and can chose the sunny days I would have pushed them for another couple thousand. From what I have read on this site you can expect to get between 8k and 15k.......you just have to keep your eye on them when you do your pre trips to know what you have left for tread.
