SPECIFICATIONS:
2003 Specifications FXSTDSE Screamin’ Eagle® Deuce™
DIMENSIONS
Length 95.4 in. (2422.0 mm)
Seat Height (measure laden w/ 180 lb. rider) 24.7 in. (629.0 mm)
Seat Height (unladen) 26.0 in. (659.6 mm)
Ground Clearance 4.7 in. (119.1 mm)
Rake (degrees) 34.0 degrees
Trail 5.1 in. (129.5 mm)
Wheelbase 66.6 in. (1690.3 mm)
Tires: Dunlop Harley-Davidson Series II
Front - D402 MH90-21 54H
Rear - K591 160/70B17 73V
Fuel Capacity (includes 0.5 gal. reserve) 4.9 gal. (18.5 L)
Reserve Fuel Capacity (warning light @ approx. 1.0 gal.) 0.5 gal. (1.9 L)
Oil Capacity 3.5 qts. (3.3 L)
Dry Weight 677.0 lbs. (307.1 kg)
Vehicle Weight In Running Order (unladen) 712.4 lbs. (323.1 kg)
Gross Vehicle Weight Rating 1125.0 lbs. (510.8 kg)
Anything else? From
2003 Harley-Davidson FXSTDSE Screamin' Eagle Softail Deuce
