Luggage Rack 07 FXSTC
Discussion in 'Softail Models' started by hackaneer99, Feb 24, 2012.
  1. hackaneer99
    hackaneer99 Member
    5
    Putting a luggage rack on the back of my 07 FXSTC with the license plate and brake light already moved to the side, anybody done similar and got any tips:D
  2. eleft36
    eleft36 Junior Member
    441
    If it's a HD rack, set it on and install the front bolt. Center it on the rear plastic mounting area.
    Heat up the short end of a suitable sized allen wrench and pierce the plastic through the holes in the rack for the rear bolts.
    Clean the globe at the bottom and bolt in place.
    Al
  3. hackaneer99
    hackaneer99 Member
    5
    Thanks Al
  4. gator508
    gator508 Well-Known Member
    2,754
    179
    If memory serves me correctly, on my '08, the license plate bracket had knockouts that I punched out and the rack (HD twisted chrome), mounted directly to it and then attached the center bolt. 15 minute job, in between cold beers!!!!
  5. eleft36
    441
    My '07 does not have knockouts.
    Al
    :USA
    :CONNECTICUT
  6. hackaneer99
    hackaneer99 Member
    5
    Thanks Gator but my 07 does not have knock outs and an 07 luggage rack won't work. I gotta try a strut mounted rack next.
  7. Jack Klarich
  8. eleft36
    441
    Mine doesn't either but I mounted it.
    Al
    :USA
    :CONNECTICUT
  9. gator508
    2,754
    179
    Sorry it didn't help, I am surprised that the 07 rack didn't work, isn't that the year of your bike, is the rack an HD, hope you get it on.
  10. wlsnow
    wlsnow New Member
    What did you all use for hardware?? My box was empty.
