Low fuel
Discussion in 'Electrical' started by Mwsharpe, Aug 29, 2015.
  1. Mwsharpe
    Mwsharpe New Member
    Low fuel warning light is working backwards.I filled the tank then the light came on.stayed till about 3/4 then went out till tank nearly empty.filled up then light came back on.I have had the bike about 3 weeks 06 dyna fxwdi.the fuel gauge is reading correctly.
  2. Jack Klarich
    Do you have the speedo/tach combo? Perhaps it is not set up right?
    Harley Davidson Forums
    Have a try here for codes first
  3. Jack Klarich
  4. Bodeen
    4,647
    73
    222
    Not a lot of info out there for the low fuel light. My light quit working all together and have not found a lot of diagnostic info on the low fuel light only.....If you find something, please do share.
  5. Mwsharpe
    Mwsharpe New Member
    Thanks to all.if i find out any thing i'l l pass it along.don't have the speedo tach combo.
