free website stats program Lost my key fob !! | Harley Davidson Forums
Lost my key fob !!
There is no problem as long as you did what you should have did. Recorded the information provided with you FOB in the provided space in your manual. If you did, like I hope you did, call HD and they will reissue one. In your manual, you can over ride your FOB. Again, if you did what you should have done and entered your own 5 digit code, use your code. If you did not, call the dealership to get the default. Mine was 55555. Let this be a lesson to everyone. Record your FOB info and set your personal pin to over ride the security in case you los or forget your FOB. Good luck.
You can get a replacement FOB at the dealer and they have to program it to the bike for you. Set the PIN the next time so you can at least start the bike without the FOB. Use the link provided above to do it. You may be able to retrieve the PIN code in your bike using that link also.
