loss of idle speed control
Discussion in 'General Harley Davidson Topic' started by jsnewk, May 2, 2011.
  1. jsnewk
    jsnewk Member
    14
    I have a 2007 Road King with 103" w/power commander. Bike will not idle down from apx 2800 rpm until wheels come to full stop. Getting a "loss of idle speed control" code. Dealer has checked throttle body for leaks w/ nothing found. Curious if anyone is seeing this problem with their power commander? Idle issue goes away when PC is disconnected but runs lean due to custom intake and pipes. Thanks to posters in advance.
  2. relxn88
    relxn88 Member
    37
    Sometimes, if the PC "0" throttle isn't set to 0 (say it was at 5 instead of 0) the engine would act accordingly. Try warming the engine up and check(using the PC control center) and see if your zeroed out. Just my 2cents.
  3. jsnewk
    jsnewk Member
    14
    Mechanic replaced trans sensor and wheel sensors. Problem still there. He clutched and cut engine at 40 mph, did a restart and engine idled normal. Once engine reaches 3000 or so rpm it comes back. The problem is not the Power Commander as it does it with or without it installed.
  4. glider
    Has anything been done with the TPS?
  5. jsnewk
    jsnewk Member
    14
    Additional: It seems to happen only after warmup. When engine is cold the problem does not exist.
  6. jsnewk
    jsnewk Member
    14
    He has cleaned it but not replaced it...
  7. glider
    I have seen where the TPS is improperly set will cause that problem you are having.
  8. jsnewk
    jsnewk Member
    14
    I will pass that on to him, thanks Glider. He and the dealers top wrenches have been at this for 3 weeks and all are scratching their heads....
  9. Hoople
    Hoople Account Removed
    7,198
    34
    So which is it?
  10. jsnewk
    jsnewk Member
    14
    It was thought to have gone away when the PC was disconnected but that proved to be temporary and does it with or without the PC connected. Sorry for the confusion.
