J
Jack Klarich
Guest
Loctite 565 Thread Sealant
Top Pick Loctite® 565™ Thread Sealant, controlled strength, is formulated specifically for metal tapered pipe thread fittings. Controlled lubricity prevents galling and protects from rust and corrosion. Loctite 565 replaces most tapes and pipe dopes. Cures rapidly to withstand 10,000 psi. Perfect as a replacement for pre-coated parts. Can be used on fittings up to 2 in. (50 mm) in diameter. CSA 3319-81 and 3319-01. UL MH007(N). NSF/ANSI 61 Certified. ULC-Canada Approved. CFIA Approved.
