Little leaker
Discussion in 'Touring Models' started by Motopsycho, May 23, 2010.
  1. Motopsycho
    Motopsycho Member
    40
    I sem to have a small leak coming out of the stator plug. Where is the oil coming from? Is it coming out of the tranny, engine, or primary? Thanks in advance.:newsmile030:
  2. HDDon
    5,560
    133
    235
    It's coming from the primary. I had a small leak on my 94 FLSTC and had to remove the plug from inside the primary and used some RTV to seal.
  3. walleye
    walleye Junior Member Contributor
    944
    3
    OK, this does not apply to me yet, but I am here to learn. What is RTV seal? :s
  4. Motopsycho
    Motopsycho Member
    40
    Thanks HDD. This sight is da bomb
  5. NEWHD74FAN
    8,191
    98
    19
    RTV = Room Temperature Vulcanization...i.e. rubber adhesive sealer that vulcanizes (cures) at room temperature.
    Advantage is it cures without mixing or long 24 hour curing additives or solvents, think about epoxy or other 2 or 3 part glues, sealers and the associated mess, expecially if not prepped correctly...
  6. HDDon
    5,560
    133
    235
    Exactly right. I used a fast cure silicone (clear).
