free website stats program Limp Mode | Harley Davidson Forums
Limp Mode
David61
Okay
This is driving me bonkers. My 09 ultra Classic was up on my lift the other day and I started it and engaged it into first for about a half a minute. Took it off the lift and it wouldn't start. Eventually after disconnecting the battery and unplugging the ECM & Bank Angle sensor and plugging them back in. I finally got it to start. I put on about 30 miles or so and it went into limp mode again. Any help would be appreciated
Did you check for any codes? That would be a good place to start
  1. Below is a list of comprehensive list of diagnostic codes that you may come across on your Harley-Davidson.
    • Sensors and Motors (P0051-P2304)
    • ABS (C0652-C1573)
    • Battery, Ignition, Lighting and Accessories (B0563-B2274)
    • CanBus (U0001-U1317)
    • Radio Diagnostics (B2006-B2027)
    How to Read Error Codes
    1. With the ignition in the off position, press and hold the trip meter button, and turn the ginition swith to the on position.
    2. Release the button. Your speedo indicators should illuminate and the needle should do a full sweep.
    3. “diag” will appear on the odometer screen. Press the trip button once.
    4. “PSSPt” is now displayed. Each of the letters represents a different area.
      • P = ECM / ICM (Engine / Ignition Control Module)
      • S = TSM / TSSM (Turn Signal / Turn Signal Security Module)
      • SP = Speedometer
      • t = Tachometer
    5. You can highlight each area by pressing the button. Once the area you wish to select is highlighted, press and hold the button for 5 seconds.
    6. If there are any codes, you will be able to go through them one at a time by pressing the button. Once you have them recorded, they can be cleared by holding the button for more than 5 seconds. Once “clear” is on the screen, press the button once more.
    7. To exit the Diagnostic Mode, turn the ignition switch off.
    Harley Sensor and Motor Codes
    POO51 Heater Control Circuit 02 Sensor Low
    PO106 Map Sensor Rate of Range Error
    P0107 Map Sensor Failed Open/Low
    P0108 Map Sensor Failed High
    P0112 IAT Sensor Voltage Low
    P0113 IAT Sensor Voltage Open / High
    P0117 ET Sensor Voltage Low
    P0118 ET Sensor Voltage Open / High
    P0120 TPS1 Range Error TPS
    P0122 TPS1 Low TPS
    P0123 TPS1 High / Open TPS
    P0131 Front 02 Sensor Low (lean)
    P0132 Front 02 Sensor High (rich)
    P0134 Front 02 Sensor Open / Not Responding
    P0151 Rear 02 Sensor Low (lean)
    P0152 Rear 02 Sensor High (rich)
    P0154 Rear 02 Sensor Open / Not Responding
    P0220 TPS2 Range Error
    P0222 TPS2 Low TPS
    P0223 TPS2 High/Open
    P0261 Front Injector Open/Low
    P0262 Front Injector High
    P0263 Rear Injector Open/Low
    P0264 Rear Injector High (CAN-Bus)
    P0264 Rear Injector Open/Low
    P0265 Rear Injector High
    P0371 Crank Position Sensor, Too Many Pulses
    P0372 Crank Position Sensor, Too Few Pulses
    P0373 CKP Sensor Intermittent
    P0374 CKP Sensor Not Detected
    P0444 Purge Solenoid (Evap. Canister) Open/Low
    P0445 Purge Solenoid (Evap. Canister) High
    P0501 VSS Low
    P0502 VSS High/Open (Can-Bus)
    P0502 VSS Speed Failed Low
    P0503 VSS Speed Failed High
    P0505 Loss of Idle Speed Control
    P0506 Idle Speed Control RPM Too Low
    P0507 Idle Air Control System RPM Higher Than Expected
    P0562 Battery Voltage Low
    P0563 Battery Voltage High
    P0572 Brake Switch Low
    P0577 Cruise Control Input High
    P0602 Calibration Memory Error
    P0603 ECM EEPROM Failure
    P0604 RAM Failure
    P0605 ECM Flash Error
    P0607 Converter Error
    P0641 5V+Vref 1 Out of Range
    P0651 5V+Vref 2 Out of Range
    P0661 Intake Solenoid Low/Open
    P0662 Intake Solenoid High/Shorted
    P1001 System Relay Coil Open/Low
    P1002 System Relay Coil High/Shorted
    P1003 System Relay Contacts Open
    P1004 System Relay Contacts Closed
    P1009 Incorrect Password
    P1010 Missing Password
    P1270 TGS Validation Error
    P1351 Front Ignition Open/Low
    P1352 Front Ignition Coil High/Shorted
    P1353 Front Cylinder No Combustion
    P1354 Rear Ignition Coil Open/Low
    P1355 Rear Ignition Coil High/Shorted
    P1356 Rear Cylinder No Combustion
    P1357 Front Intermittent Secondary Combustion
    P1358 Rear Intermittent Secondary Combustion
    P1475 Exhaust Actuation Position Error
    P1477 Exhaust Actuator Open/Low
    P1478 Exhaust Actuator Shorted/High
    P1501 Jiffy Stand Sensor Low
    P1502 Jiffy Stand Sensor High
    P1510 EFI Limited Performance Mode (TBW)
    P1511 EFI Power Management Mode
    P1512 EFI Forced Idle Mode
    P1514 Air Flow Fault (TBW)
    P1600 EFI Module Processor Internal Error
    P1632 Odometer Learned Up
    P2100 EFI TCA Motor Circuit Open (TBW)
    P2101 EFI TCA Motor Circuit Range/Performance
    P2102 EFI TCA Motor Circuit Low
    P2103 EFI TCA Motor Circuit High
    P2105 EFI Forced Engine Shutdown
    P2107 EFI Module Control Processor Internal Fault
    P2119 EFI Motor Throttle Body Range Performance (TBW)
    P2122 TGS1 Low/Open
    P2123 TGS1 High
    P2127 TGS2 Low/Open
    P2128 TGS2 High
    P2135 TPS Voltage Correlation Error
    P2138 TGS Voltage Correlation Error
    P2176 EFI Closed Postion Not Learned
    P2300 Front Ignition Coil Driver Low/Open
    P2301 Front Ignition Coil Driver High/Shortened
    P2303 Rear Ignition Coil Driver Low/Open
    P2304 Rear Ignition Coil Driver High/Shortened
    Harley ABS and Power Circuit Codes
    C0562 Device Voltage Low
    C0563 Device Voltage High
    C1014 ECU Internal Fault ABS
    C1017 Pump Motor Power Circuit Fault
    C1018 Pump Motor Ground High Resistance Fault
    C1021 Front Wheel Speed Sensor Equals Zero
    C1023 Rear Wheel Speed Sensor Equals Zero
    C1025 Front Wheel Speed Signal Intermittent
    C1027 Front Wheel Speed Frequency Out Of Range
    C1032 Front Wheel Speed Sensor Open or Shorted
    C1034 Rear Wheel Speed Sensor Open or Shorted
    C1041 Rear Actuator Circuit Low/Open
    C1042 Front Actuator Circuit Open
    C1043 Pump Motor Stalled
    C1044 Rear Actuator Circuit Open
    C1052 Rear Actuator Circuit High
    C1055 ABS ECU Internal Fault
    C1066 ECU Internal Fault
    C1094 Front Brake Switch Always On
    C1095 Front Brake Switch Open
    C1102 Rear Actuator Motor Stalled
    C1118 ECU Internal Fault
    C1121 ECU Internal Fault
    C1151 Front Wheel Release Too Long
    C1153 Rear Wheel Release Too Long
    C1158 Calibration Programming Required
    C1178 No VIN Received From ECM
    C1184 VIN Does Not Match ABS ECU Calibration
    C1192 Front Actuator Circuit High
    C1193 Front Actuator Motor Stalled/td>
    C1206 Front Wheel Speed Sensor Frequency Out of Range
    C1207 Rear Wheel Speed Signal Intermittent
    C1208 Rear Wheel Speed Sensor Frequency Out of Range
    C1212 Front or Rear Brake not Applied With Decel
    C1214 Rear Brake Switch Always On
    C1216 Rear Brake Switch Open
    C1222 ABS Voltage Low Terminal 11
    C1223 ABS Voltage Low Terminal 20
    C1224 Front Actuator Power Shorted High
    C1225 Rear Actuator Power Shorted High
    C1561 Front Apply Solenoid Circuit Open or High
    C1562 Front Apply Solenoid Circuit Shorted Low
    C1563 Front Solenoid Circuit Shorted High
    C1564 Front Release Solenoid Circuit Open or High
    C1565 Front Release Solenoid Circuit Shorted Low
    C1567 Rear Apply Solenoid Circuit Open or High
    C1568 Rear Apply Solenoid Circuit Shorted Low
    C1571 Rear Solenoid Circuit Shorted High
    C1572 Rear Release Solenoid Circuit Open or High Resistance
    C1573 Rear Realease Solenoid Circuit Shorted Low
    Harley Battery, Ignition, Lighting Codes
    B0563 Battery Voltage High TSM / TSSM
    B1004 Fuel Level Sending Unit Low Instruments
    B1005 Fuel Level Sending Unit High / Open
    B1006 Accessory Line Overvoltage
    B1007 Ignition Line Overvoltage Instruments
    B1008 Reset Switch Closed Instruments
    B1101 LHCM Turn Signal Bulb Out
    B1103 LHCM Internal Fault
    B1121 Left Turn Output Fault TSM / TSSM
    B1122 Right Turn Output Fault TSM / TSSM
    B1123 Left Turn Output Short to Ground TSM/TSSM
    B1124 Right Turn Output Short to Ground TSM/TSSM
    B1125 Left Turn Output Short to Battery TSM/TSSM
    B1126 Right Turn Output Short to Battery TSM/TSSM
    B1131 Alarm Output Low TSSM
    B1132 Alarm Output High TSSM
    B1134 Starter Output High TSM/TSSM
    B1135 Accelerometer Fault TSM/TSSM
    B1136 Accelerometer Tip Test Error TSSM
    B1141 Ignition Switch Open / Low TSSM
    B1142 Smart Security System Internal Fault TSSM
    B1143 Security Antenna Short To Ground TSSM
    B1144 Security Antenna Short To Battery TSSM
    B1145 Security Antenna Open TSSM
    B1151 (Sidecar) BAS Low TSM/TSSM
    B1151 RHCM Turn Signal Bulb Out
    B1152 (Sidecar) BAS High TSM/TSSM
    B1153 (Sidecar) BAS Out Of Range TSM/TSSM
    B1153 RHCM Internal Fault
    B1154 Clutch Switch Input Short To Ground
    B1155 Neutral Switch Input Short To Battery
    B1200 Instrument Internal Fault
    B1210 Fuel Sender Shorted Low / Fuel Gauge Circuit
    B1211 Fuel Sender Shorted High / Open
    B2102 System Power Output Shorted High
    B2103 System Power Output Shorted Low
    B2104 System Power Output Overloaded
    B2107 Front Position / Running Power Output Shorted High
    B2108 Front Position / Running Power Output Shorted Low
    B2109 Front Position / Running Power Output Overloaded
    B2112 Accessory Output Shorted High
    B2113 Accessory Output Shorted Low
    B2114 Accessory Output Overloaded
    B2116 Fuel Pump Output Open
    B2117 Fuel Pump Output Shorted High
    B2118 Fuel Pump Output Shorted Low
    B2119 Fuel Pump Output Overloaded
    B2121 Starter Output Open/BCM Malfunction
    B2122 Starter Output Shorted High
    B2123 Starter Output Shorted Low
    B2124 Starter Output Overloaded
    B2126 Horn Output Open
    B2127 Horn Output Shorted High
    B2128 Horn Output Shorted Low
    B2129 Horn Output Overloaded
    B2131 High Beam Output Open
    B2132 High Beam Output Shorted High
    B2133 High Beam Output Shorted Low
    B2134 High Beam Output Overloaded
    B2136 Low Beam Output Open
    B2137 Low Beam Output Shorted High
    B2138 Low Beam Output Shorted Low
    B2139 Low Beam Output Overloaded
    B2141 Left Front Turn Signal Output Open
    B2143 Left Front Turn Signal Output Shorted Low
    B2144 Left Front Turn Signal Output Overloaded
    B2146 Right Front Turn Signal Output Open
    B2148 Right Front Turn Signal Output Shorted Low
    B2149 Right Front Turn Signal Output Overloaded
    B2151 Left Rear Turn Signal Output Open
    B2153 Left Rear Turn Signal Output Shorted Low
    B2154 Left Rear Turn Signal Output Overloaded
    B2156 Right Rear Turn Signal Output Open
    B2158 Right Rear Turn Signal Output Shorted Low
    B2159 Right Rear Turn Signal Output Overloaded
    B2161 Brake Lamp Output Open
    B2163 Brake Lamp Output Shorted Low
    B2164 Brake Lamp Output Overloaded
    B2166 Running Lights Output Open
    B2168 Running Lights Output Shorted High
    B2169 Running Lights Output Shorted Low
    B2172 Security Siren Output Shorted High
    B2173 Security Siren Output Shorted Low
    B2176 Security Antenna Output Open
    B2177 Security Antenna Output Shorted High
    B2178 Security Antenna Output Shorted Low
    B2203 Ignition Switch Input Shorted Low
    B2206 Engine Stop Switch Input Open/Shorted High
    B2208 Engine Stop Switch Input Shorted Low
    B2218 Neutral Switch Shorted Low
    B2223 Rear Brake Switch Shorted Low
    B2250 Clutch Switch Stuck
    B2251 Horn Switch Stuck
    B2252 High Beam Switch Stuck
    B2253 Low Beam Switch Stuck
    B2254 Left Turn Switch Stuck
    B2255 Trip Switch Stuck
    B2260 Start Switch Stuck
    B2261 Right Turn Switch Stuck
    B2262 Front Brake Switch Stuck
    B2263 Hazard Switch Stuck
    B2270 BCM Internal Fault
    B2271 BCM Low Voltage
    B2272 BCM or Speedometer Voltage High
    B2274 Constant Battery Line Fault
    Harley CAN Bus Codes
    U0001 CAN bus Fault
    U0011 CAN bus Low Shorted / Can bus High
    U0100 Lost Communication With ECM
    U0121 Lost Communication With ABS
    U0140 Lost Communication With BCM
    U0141 Lost Communication With LHCM
    U0142 Lost Communication With RHCM
    U0156 Lost Communication With Speedometer
    U1016 Loss of ICM/ECM Serial Data
    U1040 Loss OF Communication With ABS
    U1064 Loss Of TSM/TSSM Serial Data
    U1097 Loss Of Speedometer Serial Data
    U1255 Missing Message at Speedometer EFI
    U1300 Serial Data Low
    U1301 Serial Data Open/High
    U1302 Infotainment Bus Off
    U1306 Infotainment Bus Lost Communication With Handsfree Phone
    U1307 Infotainment Bus Lost Communication With CB
    U1308 Infotainment Bus Lost Communication With Future
    U1312 Infotainment Bus Lost Communication With Future
    U1313 Infotainment Bus Lost Communication With Radio Satellite
    U1314 Infotainment Bus Lost Communication With Navigation
    U1317 Infotainment Bus Lost Communication With High-Out Amplifier
    Harley Radio Diagnostic
    B2006 Radio Switch Stuck or Open
    B2007 Handlebar Switch Shorted High
    B2008 Handlebar Switch Shorted Low
    B2009 Handlebar Switch Stuck or Open
    B2010 Passenger Switch Shorted High
    B2011 Passenger Switch Shorted Low
    B2012 Passenger Switch Stuck or Open
    B2013 Sidecar Switch Shorted High
    B2014 Sidecar Switch Shorted Low
    B2015 Sidecar Switch Stuck or Open
    B2016 Front Speaker Shortened R1.0 Ohm When Setup
    B2017 Front Speaker Opened R>100 Ohms Tested Once per Ignition Cycle Ignition ON after Ignition Off for 10 sec.
    B2018 Front Speaker Shortened to Ground Ignition ON After Ignition OFF for 10 sec.
    B2019 Front Speaker Shortened to Battery Ignition ON After Ignition OFF for 10 sec.
    B2020 Rear Speaker Shortened R1.0 Ohm When Setup
    B2021 Rear Speaker Opened R>100 Ohms Tested Once Per Ignition Cycle Ignition ON After Ignition
    B2022 Rear Speaker Shortened to Ground Ignition ON After Ignition OFF for 10 sec.
    B2023 Rear Speaker Shortened to Battery Ignition ON After Ignition OFF for 10 sec.
    B2024 Sidecar Speaker Shortened R1.0 Ohm
    B2025 Sidecar Speaker Opened R>100 Ohms Tested Once Per Ignition Cycle Ignition ON After Ignition OFF for 10 sec.
    B2026 Sidecar Speaker Shortened to Ground Ignition ON After Ignition OFF for 10 sec.
    B2027 Sidecar Speaker Shortened to Battery Ignition ON After Ignition OFF for 10 sec.
    Sensors and motor
    Sensors and motorHarley-Davidson Fault Code Abbreviations
    Sensors and motor
    ABS – Anti-Lock Braking System
    ACR – Automatic Compression Release
    AFR – Air Fuel Ratio
    AIS – Active Intake Solenoid
    ATS – Air Temperature Sensor
    BAS – Bank Angle Sensor
    BCM – Body Control Module
    CAN – Controller Area Network
    CCM – Cruise Control Module
    CKP – Crank Position Sensor
    DLC – Datalink Connector
    DTC – Diagnostic Trouble Codes
    ECM – Electronic Control Module
    ECT – Engine Coolant Temperature
    ECU – Electronic Control Unit
    EFI – Electronic Fuel Injection
    EFP – Electronic Fuel Pump
    ET – Engine Temperature sensor
    FI – Fuel Injectors
    FPR – Fuel Pressure regulator
    H-DSSS – Harley-Davidson Smart Security System
    HCU – Hydraulic Control Unit, ABS
    [/stag_one_half][stag_one_half_last] HFSM – Hands Free Security Module
    HO2S – Heated Oxygen Sensor
    IAC – Idle Air Control actuator
    IAT – Intake Air Temperature sensor
    ICM – Ignition Control Module
    IMAP – MAP + IAT in one unit
    ISS – Ion Sensing System
    JSS – Jiffy Stand Sensor
    LHCM – Left Hand Control Module
    MAP – Manifold Absolute Pressure Sensor
    MHR – Right Hand Control Module
    RCM – Reverse Control Module
    TCA – Throttle Control Actuator
    TGS – Twist Grip Sensor
    TMAP – Intake Air Temperature / Manifold Absolute Pressure equipment
    TPS – Throttle Position Sensor
    TSM / TSSM – (Turn Signal / Turn Signal Security Module)
    VE – Volume Efficiency
    VIN – Vehicle identification number
    VSS – Vehicle Speed Sensor
    WSS – Wheel Speed Sensor
    Self Help Information and Tips<< click me!
    (Disclaimer) I may not always be right but at least I tried. 05 Ultra Classic 95 ci.
Welcome to the forum from Gulf Coast AL. Try putting a new battery in the fob, it can't hurt and if you haven't changed it in awhile it can leave you stranded.
