Light short ??
Discussion in 'Electrical' started by SpringerBill, May 15, 2009.
  1. SpringerBill
    SpringerBill Member
    5
    I have a 96 Springer and I can ride at night for about 15 minures and my headlights and tail lights will go out. After about 30 seconds and they come back on for a while. It scarey to ride at night now.
  2. TQuentin1
    4,737
    142
    I'll bet!! Sounds like a bad ground, broken wire making intermittent contact or a bare wire somewhere that is grounding out. I hate these kind of problems because they are very time consuming to find.
    Good luck!
  3. jims87flh
    jims87flh Banned
    95
    If you just leave it sitting, not running with the lights on for 15-20 minutes, do they go out, or only when you are running the motor/riding?
  4. glider
    50
    How about replacing the main breaker? They get tired after years of use and heat.
  5. NEWHD74FAN
    8,191
    98
    19
    If it was a "short" circuit, heating and smoke would result. An intermittant open is likely the problem. If Glider's suggestion does not fix problem, you may want to check for corrosion at, in and around the battery, main breaker/fuse box next, clean all contacts and connections, coating with dielectric grease. If still present, work your way forward towards headlamp and controls or rearward for the live all the time license/taillight. You can "tap" around with the handle of an insulated screwdriver, along the main wiring harness up to and including the handlebar controls and headlight or tailight housing/wiring. Having a little history may help, but by now a lot of things in the circuit probably have been disturbed already, making intermittant problem solving even tougher.
  6. Bubbaglide
    Bubbaglide Member
    67
    Since it resets after time, a circuit breaker tripping would be my best guess may find a chafed wire or bad ground
    Good luck and have patience
    Bubba
