free website stats program Lifter Noise | Harley Davidson Forums
Lifter Noise
Joe2007ultra
Hi all
Been awhile since I have been here. Ok so I have read all the issues about lifter noise on twin cam 96 and 103 engines.
My 2010 Ultra is obviously having same problem. So is there anyone out there that has totally fixed the problem and what did you do to fix it. New Lifters? Oil brand and weight? Any info would be greatly appreciated.
I have found that on my Engine kit that I installed I measured the push rods threads and found them different 27 threads per inch to 29. Adjusted push rods per manual then added 2 then 3 then and finally 4 additional turns and it stoped the chatter. I have a 2010 with 113 build. Just make sure to follow the instructions in Manual for your bike. Have a mechanic friend and that helps but I did work and was not that hard. To hold covers out of your way rubber band and small paper clip work great.
