Lifter configuration
Discussion in 'Engine, Fuel and Exhaust' started by TQuentin1, May 17, 2009.
  1. TQuentin1
    4,737
    142
    I am swapping out the old lifters for a new set of replacement "B"s. I have always thought that since these lifters do not rotate due to the anti-rotation pin, it does not matter which way the oil port in the side of the lifter faces. But my question is, DOES it matter which way the oil ports in the side of the lifers face? Should they face each other, face away from each other, both left, both right, or doesn't matter? What do you guys think? I can find no discussion of this in my service manual.
  2. dolt
    dolt Senior Member
    2,172
    103
    334
    Doesn't matter, put them in the way you want.
  3. The4opps1
    The4opps1 Junior Member
    646
    3
    From what I have gathered, on an old set of lifters minding oil port direction when reinstalling was a way to insure that the rollers were turning the same direction as when pulled out. On new lifters that obviously doesn't make any difference.
  4. NEWHD74FAN
    8,191
    98
    19
    New installation does not matter, but once installed, the wear pattern is established so they should be installed in the same hole and direction for the roller/pinned type lifters to maintain the same wear pattern relationship with the cams.
  5. TQuentin1
    4,737
    142
    For those of you that have never seen the guts of a lifter (like me before today!!), check out the pix below. These are HD "B" lifters.
    Someone explain the way these things work.
