Leaky Gaskets On 85' FXRS Rocker Box Covers
Discussion in 'FXR Models' started by Wacka52, Nov 27, 2012.
  1. Wacka52
    Wacka52 Member
    5
    Is there any easier way to replace the rocker box covers on a 1985 FXRS stock engine besides pulling the engine out?
  2. fin_676
    5,779
    153
    285
    I have had no trouble removing rocker boxes with the engine in the frame on my softail dyna and sportster although the rear one is a wee bit tight and some minor modification to tools was required to get to the fasteners
  3. Jack Klarich
    Welcome to The Forum, have you tried lowering the motor by removing the motor mount?
  4. Breeze3at
    Breeze3at Well-Known Member
    4,924
    224
    I remember that the FXR's were difficult to remove the rear rocker bolt and cover. Like Jack mentioned, I seem to remember removing the front motor mount rubber to drop the engine a bit, and disconnecting the stabilizer link so the engine could be pushed slightly sideways was the method. I'll dig around and see if I saved one of the articles.
  5. Wacka52
    Wacka52 Member
    5
    Ok thanks, I'll keep these ideas in mind. It would sure make life a bit easier. Thanks for the responses.
  6. Breeze3at
    4,924
    224
    I wasn't able to find the old articles, but googling, "replace fxr rocker box" will get several hits about the procedures.
  7. STEVE07
    4,125
    68
    85
    When I did the rocker boxes on the FXRS I took the scissor jack out of my wifes van and slid it under the motor and jacked it up so there was just a bit of pressure on it.Then I undid the motor mounts and lowered the motor with the scissor jack.Made it easy to remove the boxes.When I had the covers off I checked them with a straight edge and lightly filed the warpage out of them before I put them back on with new gaskets.
    Hope this helps.
  8. Wacka52
    Wacka52 Member
    5
    Thank you. Lots of good info.
  9. Jack Klarich
    Be sure to warm that Evo up before riding, this is the most common reason rocker boxes leak:s
